Is this good price for A1 service?
Asian07RL
My Acura RL 07 has 5,000 mile and the A1 service message is on.
I made an appointment to bring my car for service and they quote me $37.95 plus tax.
Also, they posted other service charges on line:
Service Special Price
Montgomeryville Acura "Value-Added" Service Committment
We take the manufacturer's recommendation for service on your Acura very seriously and will recommend necessary services only. Click on the plus sign to view service description
We Offer:
Written estimate for work
Check Vehicle for Recalls
Test Battery Condition Each Time
Loaner Vehicle for Major Service
Extended Hours and Saturdays
Local Shuttle Service
First Free Oil Change
Free Lifetime PA State Inspections
Automatic Car Wash (Complimentary)
Wash Vehicle (Automatic Car Wash)
-- Complimentary
Service (A) Maintenance Minder
Replace engine oil and filter.
Replace drain washer.
Top up fluids inc. washer solvent.
Test battery and report condition.
-- $37.95 Plus Tax and Shop Supplies
Service (B) Maintenance Minder
Replace Engine Oil and Filter
Replace Drain Washer
Inspect Front and Rear Brakes
Check Parking Brake Adjustment
Inspect Tie-Rod Ends, Steering Gearbox, and Rack Boots
Inspect Suspension Components for Damage
Inspect Drive Shaft Boots for Cracks and Leaks
Inspect Brake Hoses and Lines (including ABS)
Check all Fluid Levels, Condition of Fluids, and Check for Leaks
Inspect Exhaust System for Damage and Leaks
Inspect Fuel Lines and Connections
-- $121.00 Plus Tax and Shop Supplies
Service (2) Maintenance Minder
Replace Air filter Element
Replace Dust and Pollen filter (cabin filter)
Inspect Drive Belts
-- $154.28 Plus Tax
Computer Spin Balance 2 Wheels (Rotate Inc.)
Includes:
Remove Four Wheels From Vehicle
Balance and Rotate Front Wheels
Computer Spin Balance Front Wheels (We balance the front wheels using our "Road Force Electronic Computer Balancer" to eliminate the possibility of a vibration when driving.)
This is our Dealership Recommendation.
-- $39.95 Plus Tax
Service (1) Maintenance Minder
Rotate Tires
-- $39.95 Includes Computer Spin Balance Front Wheels
Service (3) Maintenance Minder
Replace Transmission Fluid
Replace Transfer Fluid
-- $112.95 Plus Tax
Service (4) Maintenance Minder
Replace Engine Spark Plugs
Replace Timing Belt
Inspect Water Pump**
Inspect Engine Valve Clearance
**We recommend water pump replacement
-- $1,159.38 Plus Tax and Shop Supplies
Service (5) Maintenance Minder
Drain and flush engine coolant
Use Honda/Acura Genuine Antifreeze
-- $81.95 Plus Tax and Shop Supplies
Service (6) Maintenance Minder
Replace rear differential fluid (clutch & hypoid
chambers) (SH-AWD)
-- $74.95 Plus Tax and Shop Supplies
Brake Fluid Flush (Every 3 Years)
Using specialized equipment, we flush out old contaminated brake fluid in your complete brake system. We then install new brake fluid and test for the poper operation.
-- $111.95 Plus Tax.
Replace Wiper Inserts
Replace Your Worn Out Wiper Blades with Genuine Factory Wiper Inserts.
-- $19.95 Plus Tax
PA State Inspection (CP)
Perform Penna State Inspection
Free if vehicle purchased from Montgomeryville Acura
-- $26.00 Plus Tax (Free if vehicle purchased at Montgomeryville Acura)
PA Emission Inspection
Perform Pa Emission Inspection
-- $48.95 Plus Tax
Alignment (Computer Four Wheel)
Includes:
Precisely measure and adjust front wheel and rear wheel alignment to factory specifications.
Web Only! $89.95 $79.95 Plus Tax. Parts Extra if Needed.
Battery Terminal Service
We test your battery condition, and clean your battery and battery posts with a special cleaner and lubricate to prevent cable corrosion.
-- $24.95 Plus Tax
Rotate Tires
Inspect Drive Belts
-- $154.28 Plus Tax
-- $112.95 Plus Tax
Replace Timing Belt
chambers) (SH-AWD)
We Offer:
-- Complimentary
Inspect Drive Belts
-- $154.28 Plus Tax
Includes:
-- $39.95 Plus Tax
Rotate Tires
-- $112.95 Plus Tax
Replace Timing Belt
chambers) (SH-AWD)
-- $19.95 Plus Tax
-- $48.95 Plus Tax
Includes:
-- $24.95 Plus Tax
Rotate Tires
Inspect Drive Belts
-- $154.28 Plus Tax
-- $112.95 Plus Tax
Replace Timing Belt
chambers) (SH-AWD)
I am assuming by your post you add the prices together for each letter and number. In southern california I called the dealer for A1 sevice was told $69.95 addition $25 for Mobil 1 oil.
I don't think I will ever pay for services like oil change or air/Cabin air filter change for my RL. It's just ridiculous. I was quoted $500.00 for the 30K miles tune up which includes the oil and filter change, air filter change, cabin air filter change and tire rotation. I did all the job myself and perhaps just spent about a 100 bucks.
Go Big Blue!
I just called Montgomeryville about the A16 service. They quoted $153 for the oil change, rotate/balance, and differential fluid change, which is what these services add to based on your numbers above (actually $152.85). Davis (my dealer) wanted $161 without the tire balancing (but met Montgomeryville's offer) so it appears that Montgomeryville is certainly in the ballpark.
LL
LL
I had the A1 service at Montgomeryville this morning, including 100% synthetic oil and they didn't charge me anything. Maybe because I bought an extended warranty?
Since I purchased my car at Davis, I get every other oil change free. Perhpas Montgomeryville has a similar deal. I don't use synthetic so I don't know if they would charge me for the oil if I did.
LL
LL
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
