Worn Acura "A" on steering wheel
Old 01-29-2012, 04:08 AM
Joseprofet's Avatar
The Acura "A" on my steering wheel is chipping and not looking so great... Short buying another airbag is there a way to replace just the "A"?
Old 01-29-2012, 09:40 AM
HEAVY_RL's Avatar
https://acurazine.com/forums/2g-rl-2005-2012-76/replacement-acura-logo-airbag-816377/
Old 01-29-2012, 12:05 PM
Joseprofet's Avatar
Wow lol.... I'll pass
Old 01-29-2012, 01:10 PM
HEAVY_RL's Avatar
Most of us have... I am planing to paint mine
Luckily I pealed the chrome off and the color underneath kinda matched my interior
Old 01-29-2012, 01:57 PM
Joseprofet's Avatar
Keep us updated on that... I'm gonna paint the circular grayish silver trim on the sides of the rear vent, that should be a lot easier lol
Old 01-29-2012, 03:00 PM
Sniffles's Avatar
If you have black interior like I do, I plan on masking the steering wheel off and just spray paint the emblem with plastidip. Worse case scenario is that I peel the "black rubber" off if I don't like it =)
rlx015 (12-13-2016)
Old 01-29-2012, 07:23 PM
Joseprofet's Avatar
I guess gently peel away the chrome with a blade?
Old 02-02-2012, 10:36 PM
2005 RL black on black
jerztl's Avatar
i have done this.. Warning i suggest you take the battery terminals on your car. You will need a new emblem.
1. the emblem is being held from the back by if i remember correctly 8 plastic pins and are melted flat to hold the emblem.
2. I got one of those pick & hook set put the hook and start pulling the emblem
3. The emblem is plastic so it tends to expand then use a small fine tip x-acto knife and start cutting the pins towards the bottom of the emblem.
4.once you start cutting the pins them emblem starts to be more flexible and you can start putting it with the hook easier and easier to cut.
5. once you cut all the pins whole emblem is off
6. i had 2 emblems i decided to take all the chrome off the emblem and make it white so it stands out and it different. I soaked it on paint thinner to clean it up. i cut the plastic pins to half their size and used some crazy glue on the pin holes and done push the emblem in.
7. plug the battery terminals back on.
I will post pics tomorrow if i get a chance so you guys can see what it looks like.
HEAVY_RL (02-03-2012)
Old 02-03-2012, 09:41 AM
db22's Avatar
A worn Acura A?? How do you wear it out - keep falling asleep at the wheel and drooling over the "A"?
Old 02-03-2012, 10:01 AM
plastikman's Avatar
Yeah I was wondering the same thing, do you drive with your hand on the A ? I'm just trying to picture this and all. Good luck with the fix.
Old 02-03-2012, 02:08 PM
jerztl's Avatar
Here are some pics
http://www.flickr.com/photos/38912461@N07/6813345069/
http://www.flickr.com/photos/3891246...n/photostream/
Old 02-04-2012, 04:41 AM
Joseprofet's Avatar
Wear and tear.... They say it's from using cleaners on the steering wheel, I'm not the first owner.
Old 06-29-2012, 02:25 PM
IanVS's Avatar
Heavy, did you ever get around to painting your emblem? Mine's doing the same thing, and it looks like crap.
Old 06-29-2012, 06:57 PM
IanVS's Avatar
I'm thinking of getting some fake chrome spray paint, spraying it in the lid, and using a brush to touch up the emblem. Anyone tried that?
Old 06-29-2012, 10:11 PM
BuLtL00's Avatar
when i was looking to buy an RL a year ago i found a NBP/ebony w/56k miles,A-spec kit and didnt buy it because the emblem on the airbag was worn bad!!LOL i know but it just trew me off,interior was also worn pretty bad!!!Glad i passed because the one i have now is in great shape.I guess i all depends on the people who owned it first.
Old 06-29-2012, 10:18 PM
IanVS's Avatar
That's the thing, the rest of my interior is almost perfect. Which makes the worn emblem all the more annoying.
Old 06-29-2012, 10:50 PM
forcemac101's Avatar
Silver Metallic paint pen? Might be a bit ghetto...could be worth a try though..?
Old 06-29-2012, 11:04 PM
IanVS's Avatar
I thought about trying that, but the emblem is pretty reflective, so I'd have to scrape all the old finish off first. Then I'd risk getting paint on the surrounding wheel and would really be hosed. Since the worn out areas are the middle raised parts, if I can just touch up those areas it will be a lot easier and safer. I think. Remains to be seen how well it'll match, but anything will be better than how it is now.
Old 06-30-2012, 10:21 AM
Ballinger's Avatar
If you can get it off, you can have it "rechromed"...just yellow page a chrome shop that does small parts.
Old 06-30-2012, 11:28 AM
oo7spy's Avatar
There are other threads on this where members just bought the emblem for cheap and replace it.
Old 06-30-2012, 11:53 AM
IanVS's Avatar
Ya, but it seems like a giant PITA to get it off.
stevieray (03-01-2014)
Old 06-30-2012, 12:04 PM
oo7spy's Avatar
Getting the air bag off is a breeze. That takes 5 min tops once you are ready. I didnt care to see how the cover was attached, but I doubt it would take more than 5 min too. I disassbled my entire wheel in less than 30 min and spent the most time with the puller which you won't need.
Old 06-30-2012, 12:12 PM
IanVS's Avatar
From the one thread it sounded like there are rivets you have to drill out and plastic pins to melt. I think I'll try painting first. If that doesn't work, I'll try replacing it. If it does work, and then maybe I'll have a way of repairing the chrome strips on the bumper protectors.
Old 06-30-2012, 02:28 PM
IanVS's Avatar
As you may have expected, my plan did not work. I tried using some Kraplon on a flaked off section of one of my bumpers first, here are the results.
First a pic of the can. Notice how nice and reflective the cap is.
Here's a before shot:
And then the after (still somewhat wet, I wanted to be able to wipe it off while I still could, which I did):
So you can see, this would not be a brilliant thing to use to try to match chrome, unfortunately. I wonder if anyone sells film sheets that you can cut out and glue on, although that would probably be harder than just taking the dang thing off and replacing it. I've just got so much damaged chrome that I'd like a good way to repair it.
And just to be complete, here's how my emblem looks:
Old 06-30-2012, 05:24 PM
oo7spy's Avatar
There is a picture in another thread, and someone above explained it pretty well. It is a simple plastic piece with straight pins sticking into the air bag cover. Once the pins are in, they melted them a little to keep from slipping out. Glue would also work.
Old 06-30-2012, 06:12 PM
IanVS's Avatar
Yes I understand the concept. Maybe I'll give it a try sometime if I can find an emblem for sale somewhere (eBay seems fresh out). And I'll apparently need a rivet gun as well. Seems like the options are: 1) live with it as-is, 2) paint the whole thing a different color, or 3) spend the time to do it right and replace it. Leaning towards option 1 for now. Anybody else have luck painting theirs, though?
Old 06-30-2012, 11:48 PM
Megatron's Avatar
There's an option 4. Replace the airbag!
Old 07-01-2012, 07:15 AM
neuronbob's Avatar
This. Messing with airbag if you're not proficient= . Not a risk I wish to take.
Old 07-03-2012, 08:54 AM
EL19's Avatar
I find plenty of airbag emblems on ebay all the time. I need to replace mine. I'll do it when I get a wood wheel
Old 12-18-2013, 02:23 PM
kostantinos's Avatar
I have some
Old 12-18-2013, 03:03 PM
oo7spy's Avatar
:ibthelock/ban/postdeletefromanonpayingvendor:
Old 12-18-2013, 03:05 PM
oo7spy's Avatar
Too many threads on the same topic.
A picture is worth 48 words apparently.
Old 12-18-2013, 04:59 PM
HEAVY_RL's Avatar
you also have a thing for tomatoes.
Old 12-23-2013, 08:16 AM
just trying to help people out
just as I was frustrated with the faded logo's
put them on ebay
Old 12-27-2013, 05:48 PM
mjay's Avatar
Do you still have Acura emblems available? If so, price to buy and ship to Alabama?
Old 12-27-2013, 07:28 PM
I have some
23 shipped
Old 12-28-2013, 07:51 PM
oo7spy's Avatar
put them on ebay
I understand. I don't make the rulez here. It is suggested to take the selling of anything to PM if you are not a vendor.
Just trying to help out.
Old 02-28-2014, 03:53 PM
acurarl2005pr's Avatar
Having the same issue... will look into it.
Old 07-21-2018, 01:22 PM
rlx015's Avatar
I recently replaced the steering wheel and at the same time decided to plasti-dip the worn emblem... Here is how it looks after the install back...
Is it perfect, like factory 100% perfect - I have to say it is not... But it is far better than chipped worn out emblem from for sure 😁😁😁
kcjohnnyboy (08-15-2018)
Old 07-21-2018, 05:44 PM
projektvertx's Avatar
Good use of plastidip
rlx015 (07-22-2018)
james357
02-13-2016 02:37 PM
SpraykwoN
ILX
09-11-2015 08:45 PM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
MyKids&Cars
09-02-2015 12:03 AM
Quick Reply: Worn Acura "A" on steering wheel
