I-018: Heavy Vs NavTool...
Old 07-30-2010, 10:48 PM
HEAVY_RL's Avatar
As promised here we go, another DIY.
The NavTool comes nicely packaged
In the box you get a hard wired harness (to the box), a power cable, the factory splice harness, and instructions.
I took pics to help you guys figure out where to connect these wires, please remember that I am not a technician so go easy on the flames.
First things first... THIS IS NOT THE BOX YOU ARE HOOKING INTO!!
I talked to a few people who were severely confused about this because the NavTool harness matches perfectly with this harness.
With that out of the way, the nave unit is hanging from the rear deck lid and to get it out you have to pull the under carpet down.
The hardest part of this whole job was getting this damn clip out, good luck.
You have to pop this off to get the deck lid carpet to drop. Once you have it off you can get the 4 screws out of the nav unit and drop it down.
Here is the back of the unit. The NavTool plug only fits one plug
Once you have it plugged in correctly just hang the nav unit back up...
Now for the other wires...
Pull down the driver side carpet wall to access the taillight harness.
You will fist notice this local ground point, this is where both of the white wires go, along with the ground for the power plug (solid black wire).
Now on to the blue wire, this is connected to the brown/gray wire (also the back up light power) NOTE I also used this wire to power the back up camera.
This wire is found in the harness below the ground cluster
Now you have grounds, and power to activate the camera when in reverse, the last connection is "accessory" power. I use quotes because the instructions say not to use constant power.
I'm sure there are a lot of places to get this, I found it in the XM harness (the box I told you not to use)
The yellow wire in the lower plug works perfectly, connect the power side of the DC plug from the box (this is the black wire with the faint white line.) I realize this looks like a hack job but I did tape it up.
The following 3 users liked this post by HEAVY_RL:
jbadw1992 (03-12-2021), JnC (09-14-2013), Türk (12-16-2013)
Old 07-30-2010, 10:49 PM
HEAVY_RL's Avatar
The last connection is to the camera video cable.
Now I went with the eBay camera that GS400 used: 2005 RL Rear View Camera Installation w/pics - AcuraZine Community
Here is the eBay user profile: eBay My World - possbay2008
That install went smooth, I too cut the wires to fish them through the trunk arm.
I hope this helps you guys.
Old 07-31-2010, 12:37 AM
jhal's Avatar
This is a great DIY! This is definitely Garage worthy.
Old 07-31-2010, 04:17 AM
vletnguyen's Avatar
nice work.
i might have to do this soon. i have the autotoys part and a back up camera also.
what made you go with this unit vs the autotoys one? are you going to use audio for music videos/movies etc?
Old 07-31-2010, 08:17 AM
HEAVY_RL's Avatar
Originally Posted by vletnguyen
nice work.
I chose this one because of the reviews my fellow RL owners gave it.
My goal in the near future is to use the USA Spec for Audio and then this for video, with an iPod dock in the center console.
Old 08-01-2010, 09:41 PM
HEAVY_RL's Avatar
I took a quick cellphone vid of the switch between nav and camera.
The green is my garage door.
http://www.facebook.com/video/?id=1083728548#!/video/video.php?v=1404377064472
Old 08-04-2010, 11:32 AM
HEAVY_RL's Avatar
One last pic of the parking deck this morning...
Old 08-04-2010, 02:19 PM
rmjse's Avatar
I'm so jealous
I just bought the Navtool unit and Camera, cant wait for them to arrive and to install it!
Old 08-04-2010, 04:02 PM
BluNosr2's Avatar
Has anyone used this camera setup in a cold climate (like -20C/0F and lower)?
Old 08-04-2010, 06:10 PM
Torch & Pitchfork Posse
TampaRLX-SH's Avatar
Very nice. The resolution looks about the same as the Acura dealer installed camera on my 06. The fish eye view is greater, and a bit more wide view. The grid lines are also a nice addition.
I would be tempted to install a video file of someone being backed over with a surprised face of fear, panic and pain. Passengers would just LOVE it.
But I am like that.
Old 08-05-2010, 08:55 AM
HEAVY_RL's Avatar
Haha, a vid file of someone getting hit would be fantastic.
The lines were a big selling point for me. I know which grid line puts me where in the spot and I'm slowly getting dependent on those lines for parallel and deck parking.
Old 08-05-2010, 06:55 PM
OLD_HATCH's Avatar
Good job man. Yeah it sure comes in handy for parralel parking. Especially on my 1G RL. The thing is huge in the rear. lol
The lines are actually pretty acurate once you get used to it.
Oh and these perticular model, the coldest Ive ever used it was at 40F. worked well. At below freezing I would expect the lcd display itself to be more of a concern though.
Old 08-06-2010, 06:26 PM
HEAVY_RL's Avatar
Awwww shizzle.... USA spec installed and now I have iPod video.
Old 08-13-2010, 08:55 AM
rmjse's Avatar
Heavy,
I got the Navtool Unit and the Camera. I started working on my car yesterday and almost died in the 98 degree weather!
After trying to remove the carpet around the Nav unit for more than an hour, I gave up. Acura has the carpet on so tight around the unit, and the subwoofer.
I will try again in a few days. Any advised on removeing the carpet?
Old 08-13-2010, 10:39 AM
HEAVY_RL's Avatar
Originally Posted by rmjse
Heavy,
That carpet sucks... the clips that hold that trim to the face of the nav box are the killer.
Pull down the push tabs one at a time until that left back corner is left and then try to get in behind it.
The clips that hold that trim ring on are on the left and right sides of the nav unit at and slide out towards you once they are released.
I cant see my pics at work (thanks firewalls) but I posted one of the DVD drive with the clips out.
I used a pair of needle nose pliers to flatten the clips while I pulled the carpet outward.
Straight PIA...
Old 08-18-2010, 11:46 AM
drcoke's Avatar
Hey Heavy RL,
I just bought a Navtool and looking to purchase a camera. Can You post a pic of your Nav screen at night? I want to have a better idea what that camera looks like when you backup in the dark.
thanks
Old 08-19-2010, 10:59 PM
HEAVY_RL's Avatar
yeah sure, here are some cell shots.
Old 08-26-2010, 01:49 PM
rmjse's Avatar
Just installed mine....thanks Heavy!
Quick question...If I want to use Video port 1 to connect external devices, does the car have to be in park to view them on the display?
Old 08-26-2010, 02:56 PM
HEAVY_RL's Avatar
Nice work.
No sir, you just take that other video wire and ground it instead of using the parking brake like the instructions call for.
I extended the wires to a switch in the console, and grounded the line and it works while the car is in motion.
Old 08-26-2010, 03:51 PM
OLD_HATCH's Avatar
Yup its in the instructions. I believe all you had to do was ground 2 extra wires for it to function while driving.
Helps on long car rides in my car with the way I have my system set up.
Old 09-29-2010, 10:33 AM
ArinO's Avatar
Why do we need navtool or similar interface to connect backup camer? There is a dedicated backup camera interface in the navigation unit (connector G, Upper left green 7 pin connector). I got this info from navigation unit service manual. I wonder 2005 RL has that this camera interface enabled or not. Has some body tried to connect a camera directly to this interface?
Interface details;
pin description
1. Power source for rearview camera
2. GND rearview camera
3. GND for video signal
4. Composite video from rearview camera
5. Shield for 1,2,4,5,7
6. Control signal for rearview camera.
Please correct me if I am wrong.
datadesigner (12-17-2011)
Old 09-29-2010, 12:57 PM
OLD_HATCH's Avatar
the navtool unit is more for adding the ability to play video on ur nav screen. The backup cam is a secondary option
from the info you provided looks like it's possible. Just need to figure out what the trigger is. Positive or ground.
Old 09-29-2010, 03:52 PM
Chapter Leader (Chicago)
RL Chi-town's Avatar
just curious as i am reading i just want to ask...
do we loose xm capabilities? this may be a dumb question. but i am not a tech person.
Old 09-29-2010, 08:38 PM
HEAVY_RL's Avatar
You lose XM1 only.
XM2 is fine from what I've seen
Old 09-30-2010, 11:43 AM
thanks...
as long as i have XM i am ok...
Old 10-05-2010, 11:31 AM
zaidiahmed's Avatar
RL 2006
I am new to this site, have been looking to add new gadgets to the car (dvd playback, rear camera). Wanted to know if someone can help me out on the camera aspect of things. I have read a few posts and there is not direct reference to the camera being used--can someone point me in the direction of what camera is ideal w/night vision, does night vision make a difference?
Old 10-05-2010, 06:35 PM
HEAVY_RL's Avatar
I think what camera we are using is pretty well documented.
Night vision is not really necessary, the back up lights seem to be plenty bright in dark situations.
Old 10-17-2010, 10:40 PM
BluNosr2's Avatar
When installing the camera unit, is there any kind of sealant around the base of the camera housing to keep moisture from potentially getting under it and entering the trunk lid? I know it's tucked up under the trunk lid release "lip" above the plate, but I seem to get a fair bit of roadspray on my plate when driving in the rain and I am concerned about salt water once the winter months arrive and the roads start getting salted.
Old 10-17-2010, 11:07 PM
UA6 SSM TL
24no7's Avatar
how much did u pay for the USA spec and how hard was the installation?? could u do a dyi hahahaha???
Old 10-17-2010, 11:19 PM
UA6 SSM TL
24no7's Avatar
for the op, have u lost ur xm-radio??
Old 10-28-2010, 11:09 PM
scottycruz's Avatar
i cnt find a place that sells the gs400 backup camera. anything else similar or is it called something else?
Old 11-01-2010, 08:46 PM
HEAVY_RL's Avatar
for the mounting on to the car, there is a foam pad that came with it, I also used a rubber grommet I had laying around.
The camera itself was totally sealed in the housing so I'm not sure if we will have issues there.
Old 11-01-2010, 08:49 PM
HEAVY_RL's Avatar
I paid 10% under retail and I had a local shop install the USspec because they charged me pennies for the install and mounting the box around the dash was almost impossible.
Someone could easily do it on their own if they dont mind pulling the dash area apart to mount the box.
No I have not, I only lost the XM1 as its dedicated to the USASpec, XM2 still works.
Old 11-01-2010, 08:51 PM
HEAVY_RL's Avatar
I used the eBay cam... the link is in my orig post.
Old 11-01-2010, 09:49 PM
UA6 SSM TL
24no7's Avatar
did u remove the navitool tho?? or do u have both of them navitool and USspec?? if so what sorta material did u buy apart from the usspec?? sorry for the tons of questions
Old 11-02-2010, 05:58 PM
HEAVY_RL's Avatar
its cool if I didn't want to help I wouldn't have posted the DIY.
Just remember I am not a technician nor an artist.
Lets try this for the visual learners. (yes I drew it in PPT haha)
Purchased:
UsaSpec, NavTool, Camera, RCAs (red, white, yellow), iPod converter to RCA
Old 11-02-2010, 07:09 PM
UA6 SSM TL
24no7's Avatar
thanks a lot man! that will be my next mod for sure
Old 11-10-2010, 01:16 PM
im baaaack!!
T-jay's Avatar
Thanks fo the write up i will be installing this with a 22" flip down monitor this winter!
Old 12-29-2010, 06:10 PM
parkmead's Avatar
Do you have a switch to change the video input since you have a camera and ipod video or does it automatic detect the video signal?
Old 12-29-2010, 06:33 PM
HEAVY_RL's Avatar
Its auto when you shift to reverse for the camera and there is a switch in the arm rest for the video.
Quick Reply: I-018: Heavy Vs NavTool...
