DIY: 1st Gen Acura RL Instrument Cluster LED Bulbs
Old 01-30-2008, 02:03 AM
Ultimate DIYer
97_RLer's Avatar
I would share the instrument cluster LED bulb conversion on 1st Gen RL. I bought the following T6.5 3-LED bulbs from an eBayer ID, warden_jp2002. The seller is an eBay power seller and lives in Hong Kong. The seller is an expert on LED bulbs and ships the bulbs so fast. The most of buyers can expect to receive bulbs in 2-5 business days.
Disclosure: I'm not related with the seller anyhow.
Anyway, I bought the 4 pairs of Spark blue and 2 pairs of Xenon white LED bulbs from him at $18 ($3 x 6 pairs) plus $6.80 (shipping). What a big deal?
The seller is no longer listing these bulbs on eBay, but you may ask him to list them or search on google to find the same LED bulbs. These are wide angle LED bulbs (Cross reference: #24 or T6.5) and 3-power LED wedge bulbs for using in instrument panel and gauges working at
12V. (FYI: #74 blubs (5 mm) are not right size on our RL, and single LED bulbs are not bright at all. They are not wide resulting a dim area. I learned it from a trial and error)
I'm not writing how to disassemble the instrument cluster in this thread. You can find a decent how to remove the instrument cluster if you search on this thread. (Caution: You must be very gentle to unscrew and tighten screws on the back panel of the instrument cluster. Otherwise you will mess up the whole cluster. And also there are two types of screws so you must memorize which one goes where.)
Here's some photo of the 3-LED dimension and installed photo on my RL.
<T6.5 3 LED Bulb Dimension>
<Spark Blue>
<Xenon White>
<Night shot photo of my 97 RL Instrument cluster>
97_RLer
The following 5 users liked this post by 97_RLer:
01RL1stimer (10-21-2017), BlkDrgn28 (04-04-2015), kc2k5champ (08-16-2014), Ken1997TL (06-06-2011), Patro (07-24-2023)
Old 01-30-2008, 03:36 PM
Ken1997TL's Avatar
Wow, very nice! I'll be sure to do this immediately!
Old 01-31-2008, 06:46 AM
2000RL's Avatar
97_RLer I commend you on your research, patience and tenacity it took to produce that amazing looking LED lighted dashboard.
Patro (07-24-2023)
Old 01-31-2008, 06:14 PM
Big Green Acura's Avatar
Anybody know how to get the speedo cluster out in the first place? I am wanting to try this, but I don't want to break anything trying to get it out.
Patro (07-24-2023)
Old 02-01-2008, 08:42 AM
Jimmay's Avatar
Yes i too would like to know how to do this. Two of my bulbs have gone out and it is extremely annoying.
Patro (07-24-2023)
Old 02-01-2008, 09:56 AM
Megatron's Avatar
97_RLer
I have a question about the daylight operation of this setup. The RL cluster is lighted at full brightness during the day (headlights not on) so are these LEDs bright enough to light up the instruments in sunlight? Also, do they dim when you turn on the headlights like the normal bulbs do? Can you also adjust brightness like normal?
Old 02-01-2008, 11:43 PM
Ultimate DIYer
97_RLer's Avatar
Basically, it is funtioning the same like normal filament bulbs. And yes, you can adjust brightness, and it is bright enough during the day too (it may not be the same brightness to the filament bulbs which gives all wavelength lights since the LED bulbs only emit very narrow wavelength light correspondent to their color). The brightness can be controlled by a control knob located below the TCS and Cruise control switch, not by the bulb or LED itself.
Patro (07-24-2023)
Old 02-02-2008, 12:03 AM
Ultimate DIYer
97_RLer's Avatar
Here are some more pics.....
Here are some more pics for your reference.........
<Nightshot-Tacometer>
<Nightshot-Speedometer>
<Nightshot-Fuel and Temp gauge>
<Day shot of instrument cluster>
<Day shot of interior>
97_RLer
The following 3 users liked this post by 97_RLer:
kc2k5champ (08-16-2014), Patro (07-24-2023), Vernondo (08-25-2023)
Old 02-03-2008, 11:26 AM
Jimmay's Avatar
hey,if you know a link on how to take apart the dash to get to the instrument cluster could you share it??? or if you wouldnt mind explaining it. Thanks
Patro (07-24-2023)
Old 02-03-2008, 01:54 PM
Ken1997TL's Avatar
Did you upgrade your navigation system too? That looks to be 2001 or newer
Patro (07-24-2023)
Old 02-03-2008, 09:50 PM
Ultimate DIYer
97_RLer's Avatar
Yes, I did!
Patro (07-24-2023)
Old 02-03-2008, 10:05 PM
Ultimate DIYer
97_RLer's Avatar
96-04 Acura RL instrument gauge cluster removal procedure
I had no time to write this procedure recently. But can't put it off since many of you asked............ And here it is!
It involves the removal of shift selector console, audio unit and climate control console, and instrument panel to remove the gauge cluster. You may need to refer the repair manual for better understanding.
1. Unscrew the shift knob.
2. Pop off the black gear select cover. There are four clips to pop off.
3. Pop off the wood console panel and pull it out to access the two bolts at the bottom (96-04). There also are four clips to pop off.
4-1. Remove the center air vent (96-98 only). There are eight clips totally. Four are up and the other are down of the center air vent. Insert a flat-head screw driver under the center air vent to pry the clips up and pull it then insert the screw driver upper the center air vent to pry the clips down and pull it gently.
4-2. Remove the two bolts on top of the center console, then, carefully pull the climate control and audio unit assembly out. You don’t need to pull it out completely (96-98 only).
4-3. Remove the center console lower carpets from each side (99-04 only). You can see a screw bolt each side. Unscrew them and then, carefully pull the climate control and audio unit assembly out. You don’t need to pull it out completely.
Now you can start to remove the instrument panel.
5. Remove the two screws located at the upside of the instrument panel.
6. Detach the four clips by gently pull the right and the bottom of the instrument panel.
7. Pull the instrument panel form the right side and top down. Use a flat-head screw driver to push the two clips from the left side air vent and pull the instrument panel.
8. Remove a connector for select and reset switch.
9. Remove 4 screws holding the gauge cluster.
10. Pull the gauge cluster and disconnect the two connectors on top back side of it.
Now the gauge cluster is out and you need to remove the back panel of it to access the 10 bulbs.
11. Remove three screws and pull the white plastic face back plate. DO NOT try to remove the front plate of the gauge cluster and DON’T touch any needle of the cluster. Otherwise, you will need a new gauge cluster.
12. Remove totally 20 screws from the back panel. There are two types of screws (6 and 14 screws). The description of the screws is shown on the board but you must not be confused with them.
13. Remove the board by pulling and swinging it.
14. Remove the 10 filament bulbs and replace with the amazing LED bulbs. LED bulbs have a polarity so you have to place them in right direction. You need to figure out which side is positive on the board. You’d better check which side is positive on each LED bulb by a 12V source even though the polarity is written on the LED bulbs. Manufacturers used to label the polarity wrong on the bulbs. It happened on me, and 4 out of 12 LED bulbs had the wrong polarity indication.
15. Installation of all things is reverse. (Caution: DO NOT push or over-tighten those 20 screws on the back side of the gauge cluster board when you unscrew or re-screw them. The plastic board is easy to be marred.)
FYI: Don’t buy the wire-lead wedge type LED bulbs. They are easy to be non-functional when you push them into the wedge base because the wire-lead between the resistor and LED is apt to be broken. The LED itself has 180,000 hours of lifetime. But all LED bulbs working on 12V directly have a built-in resistor which has 47K ohms. LED itself is only working at 3.2-3.6V, thus, it requires a resistor to work at 12V properly by ohm’s law.
Please correct me if I’m wrong. Pleae put up with wrong grammar if any........^_*
97_RLer
The following 4 users liked this post by 97_RLer:
Beatindastreets (03-11-2014), kc2k5champ (08-16-2014), Patro (07-24-2023), Vernondo (08-25-2023)
Old 02-03-2008, 11:28 PM
Jimmay's Avatar
Talking
wow this might take a saturday.
Thanks!!!!!!!
Old 02-09-2008, 02:46 AM
Ultimate DIYer
97_RLer's Avatar
Sources to find the LED bulbs
A number of folk asked me where they can buy the LED bulbs. So I searched the internet for about half an hour. At first, I’m sorry but I had misguided you that the cross reference for RL’s gauge cluster bulb is #24 but #37 (6 mm) is right bulb. As I told you #74 (5 mm) is smaller than OEM bulbs. Anyway, you can search on the internet, “T6.5 3-LED bulb”, then, you can find the same bulbs that I bought. Google will show you a number of Chinese websites. I don’t know you can directly place an order at there or not.
Anyway, the best way to get the LED bulbs that I would recommend is email to eBay ID, warden_jp2002. I’m sure that he is the cheapest and fastest in the world.
Another choice is……….
http://cgi.ebay.com/PAIR-12v-T6-5-WE...QQcmdZViewItem
I found the seller on eBay (ID: brightlightautoparts) who are in Australia. The seller are selling the same LED bulbs and a pair of the LED bulbs at AU $8.50 plus AU $15.00 shipping to USA. So expensive!!!……..
Another choice is ………
http://cgi.ebay.com/T5-37-Wedge-12V-...QQcmdZViewItem
The eBay seller (ID: p0o0ohbear) is also from Australia. The LED bulbs are not the same type but are also 3-LED wide angle bulbs. They are selling at AU $3.95 as a pair plus AU $6.00 shipping to USA. Each additional shipping fee is AU $1.00.
Good luck to find good LED bulbs at cheap price……….
97_RLer
Old 02-10-2008, 01:22 PM
この道は毛むくじゃらのマンコだらけ..
onebadna1nsx's Avatar
I think i'm doing this to my 01. Thanks buddy
Old 02-10-2008, 06:37 PM
GSARL's Avatar
Not bad - looking good , Ive been through this about a year ago and tried several different bulbs, these seem to work the best.just wondering though,on the rpm cluster half of the 6 and the 7 & 8 numbers still seem to be white and also on the fuel gauge side it all seems to show white? the mph is the only part that seems to be illuminated properly
Old 02-11-2008, 02:14 AM
Ultimate DIYer
97_RLer's Avatar
I used white LED bulbs on those places because the blue LED cannot lit the red zone as I explained above.
Old 03-06-2008, 01:14 AM
MasterD86's Avatar
nice write up. I was wondering though if these would be the correct bulbs to get. http://cgi.ebay.com.au/T5-12V-Shifte...742.m153.l1262
i think I'd like white all around the most and since 2 of my bulbs are out why not replace with led.
Old 03-07-2008, 12:01 PM
Jimmay's Avatar
I have a questions relating to the stock bulbs. Are they all clear bulbs or are there diffrent color ones. Also how many do i need? Thanks for your help
Old 03-07-2008, 06:30 PM
Ultimate DIYer
97_RLer's Avatar
Those bulbs should work fine. They are much much brighter than the OEM yellowish bulbs. Post some photos after you install them.
There are 10 bulbs. 4 for Taco, 4 for Speedo, 1 for Temp and 1 for Gas gauge. OEM bulb is only one type. It is 6.5 mm diameter and covered with a light blue tinted thin rubber.
Old 03-08-2008, 12:53 PM
Jimmay's Avatar
thanks!
Old 04-08-2008, 10:45 AM
Ultimate DIYer
97_RLer's Avatar
Here is a good news!
Finally the eBay seller, warden_jp2002, lists the same bulbs on eBay at the cheapest price. The title is "2pcs 24 T6.5 Instrument Panel 3 LED Bulbs".
Here is the link.
eBay Motors: 2pcs 24 T6.5 Instrument Panel 3 LED Bulbs(Blue/White) (item 190212426319 end time Apr-12-08 03:17:18 PDT)
Old 04-08-2008, 12:45 PM
Rampaging RL
supernick37's Avatar
i am excited...
but i am debating on the blue or red... hummm blue is rad, red is different... a bit like STi gauges...
what to do?
Old 04-08-2008, 10:48 PM
Ultimate DIYer
97_RLer's Avatar
Originally Posted by supernick37
i am excited...
what to do?
The seller is selling only spark blue or xenon white bulbs. To properly illuminate red color region in the gauge, you have to choose xenon white bulbs in that region. Blue LED bulb cannot illuminate red colored region making dark in that region.
Old 04-09-2008, 01:02 AM
Rampaging RL
yeah... i know about that... but i figure that (in my crazy symmetrical mind) i dont have a manual so i dont need to watch for redline... so i dont think ill mind
Old 04-09-2008, 10:46 PM
MasterD86's Avatar
SWEET! i was able to order 10 of the white bulbs from warden_jp2002 total was $22 shipped not bad. now when they come in, I got to find the time to put them in
Old 04-10-2008, 09:11 PM
3.5RLv-tec?'s Avatar
can I find those LEDs at radio shack or other stores?? thx
Old 04-25-2008, 08:26 PM
Ken1997TL's Avatar
Bulbs are here. Going to put them in tomorrow
Old 04-26-2008, 02:03 AM
Ken1997TL's Avatar
Ok, I ended up doing it tonight because the old lady is sick and I had nothing better to do. The dash is all torn out and I'll put that back together in the morning.
Notes:
- It is a REAL pain in the ass to remove the wood panels
- The gauges look good, but i wish the bulbs were a mixture of white/blue instead of either white and blue. You can easily guess where the blue bulb is and where the white bulb is (etc)
- It took me about 4 hours off and on to do all this. Probably will take me about 30 minutes to put it all back together. Took me so long because I was being careful and didnt want to scratch anything.
Old 04-26-2008, 11:18 PM
Ultimate DIYer
97_RLer's Avatar
Hope you like your new LED gauges, Ken!!!!! BTW, what year of RL do you have? Did you have a test light up or not? Have you check the polarity of each LED bulb? Even though the polarity is written on the bulb wedge, some of them are wrong as I mentioned earlier. So you'd better light up each LED with other 12V source to make sure of it.
Anyway, good luck on your project!
Patro (10-16-2023)
Old 04-27-2008, 11:55 AM
Ken1997TL's Avatar
I love them. I have a 2002 RL.
All the bulbs work, thanks for letting me know about the polarity issue. Two were mislabeled. The left and right gauges are blue. The center is white. Pics coming soon.
Old 05-01-2008, 11:21 AM
MasterD86's Avatar
getting ready to do this finally.(yay spring semester is over!) as far as the polarity issue, would it hurt anything if I put the bulbs in the wrong way and plug in the car to test? and if one or more don't work just switch them around?
Old 05-01-2008, 03:26 PM
Ken1997TL's Avatar
You'll be fine. Didnt have any problems when i did it.
Old 05-04-2008, 10:59 AM
WtaggiN's Avatar
Been a while since I posted here . . . just ordered all Xenon White bulbs...only 3 months late huh? Will post pictures with complete DIY images and all . . . give me a week - 2 weeks. Also should have the full 1st gen RL shop manual online...pretty cool PDF, interactive.
Old 05-05-2008, 09:09 PM
BelowRadar's Avatar
I'm looking into ordering these lights for my dash as well. Please keep all info coming ! !
Old 05-07-2008, 07:22 AM
MasterD86's Avatar
is the instructions on how do to it in that one pdf shop manual? because I have it, just all I can find in there is the bulb locations in the back. If there's another pdf post it!doin it this saturday hell yeah cant wait!
Old 05-07-2008, 12:29 PM
WtaggiN's Avatar
I believe ill have the bulbs before Saturday..they were shipped out yesterday...will post manual + DIY once I have complete the project.
Old 05-08-2008, 03:32 PM
II KRuckus II's Avatar
awesome...can't wait to see the all white pics!
Old 05-11-2008, 02:33 PM
super-rl's Avatar
Thanks 97 Rler for all the information, I really like the new look I been wanted to get ready of those yellow light for the longest, I just replace my light bulbs with the led bulbs I run into a little problem, now my speed cluster not working, I fallow all the instruction all the screws or in the right place, do you know if there a fuse that I can check or if it expensive to replace
Old 05-12-2008, 04:30 PM
WtaggiN's Avatar
Check to see that your connector screws are (1) too tight or (2) too loose. Make sure not to overtighten these screws, otherwise, you're screwed. HAHAHAHAHA, yes, I made that up. That is probably your problem, happened in my 94 ES300 when I replaced the bulbs.
Still haven't gotten my bulbs yet...hopefully they are sitting nice and snug in my mailbox right now...still going to post DIY so check for updates!
Quick Reply: DIY: 1st Gen Acura RL Instrument Cluster LED Bulbs
