AWD-shuttin off
AWD-shuttin off
So I know know some of you guys say some error codes are being cause by battery going bad but I dunno if this is considered an error code but the AWD light pops up on occasion while I'm drivin and the car sputters a bit. I turn the car off and light goes off. So a battery issue or any ideas what it could be? It wasn't that cold out tonight and didnt happen all winter here in NY. My temp gauge doesn't work at all and if it does work it's always sayin a weird temp like -22 or 22 then drops down in temp.
Replace the battery. My battery was getting low and the AWD light was coming on, when it did either AWD was disabled or was not working correctly because I noticed I was slipping very easily going up the hill to my house when there was snow on the street.
First check the battery. Second, check the rear diff fluid levels.
Hmmmm
Well I might the AWD light comes on and while I'm drivin and holdin got gas it sputters a bit then drives fine again wit light still on. Ima give it a couple more days if it keeps actin up ill change battery. I bought the car bout a year ago never change battery and I dunno when prev owner changed it. I also have a system in my car so that may contribute to battery possible going.
