Problems 04 3.5rl =[
Old 04-15-2014, 06:27 PM
tboktor's Avatar
Hey all,
I just bought a used 04 3.5RL. I have had 2 problems arise: it does not shift into over-drive, and the key keeps getting stuck in the ignition after i turn off the vehicle (i'm thinking its an ignition lock cylinder problem).
Has anyone else encountered this and/or does anyone have any advice please!?
Thanks!!!
Tim
Old 04-15-2014, 06:32 PM
tboktor's Avatar
If i might add i only have 69k on the car
Old 04-15-2014, 07:27 PM
Not_So_Fast_Eddie's Avatar
The car doesn't actually have an over drive unless I'm not understanding what your asking. And when you turn off the car push the keys forward a bit as you turn the final notch. It kind of has a lock right there and thats how you get past it.
Old 04-15-2014, 09:18 PM
tboktor's Avatar
So it's normal for my car to be at 3000 RPM going 70 miles per hour?
And I do push the key forward a little bit however the only way it will come out is if I wiggle it around a little bit and turn it counterclockwise.
Old 04-15-2014, 10:20 PM
3.5RLv-tec?'s Avatar
Yea, I think that is normal because it has only 4 gears. At 2500rpm I'm going around 60~65mph. Unless you lift your foot of the gas pedal I think it will change to different gear and RPM.
Old 04-15-2014, 10:34 PM
tboktor's Avatar
Okie doke thanks!
Old 04-15-2014, 10:40 PM
BTW, I still don't understand why you said it couldnt go into overdrive? You mean the cruse control?
Old 04-15-2014, 11:18 PM
Ken1997TL's Avatar
4th gear is overdrive though it's not terribly aggressive. Remember premium gas was about $1.20 when the car was designed and sold. The RL will STAY in 4th gear even on mountain passes, so it has plenty of torque on the highway.
tboktor (04-16-2014)
Old 04-16-2014, 11:30 AM
tboktor's Avatar
No, I thought because the car was at a high rpm at 70 mph that it wasn't shifting into the last gear.
Old 04-17-2014, 03:49 PM
OhaiOh's Avatar
Nope its just an old 4 speed tranny, but id take the 4 speed over the shitty brittle 5 speed they stuck in the TL, Accord etc any day
Fabvsix (04-18-2014)
Old 04-22-2014, 01:10 PM
pmendoza502's Avatar
hmmmm i always thought 02-04 had the 5speed autos....
Old 04-22-2014, 04:07 PM
RL-R0ckst/\r's Avatar
I drive an 02 and can confirm its a 4 speed thankfully.
Old 04-22-2014, 05:20 PM
georgy_d28's Avatar
No they all had the 4 speed auto. Mine is at 3k @ 80mph
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
12vancover
10-16-2015 12:04 PM
Matthew Purpura
09-25-2015 06:10 PM
MikeJM310
09-24-2015 07:24 PM
Quick Reply: Problems 04 3.5rl =[
