Bridgestone Potenza S04
Bridgestone has stepped up their game again. This time they have lowered their pricing on the Potenza S04 Pole Position maximum performance tire while at the same time there is a $70 mail in rebate offer running.
Here's the new pricing (included pricing, for all sizes):
the lone 16" size
205/55R16 $105
17's
205/45R17 $110
205/50R17 $122
215/45R17 $114
225/45R17 $121
235/45R17 $131
235/50R17 $131
245/40R17 $146
245/45R17 $136
255/40R17 $159
18's
215/45R18 $134
225/40R18 $152
225/45R18 $154
225/50R18 $119
235/40R18 $156
245/35R18 $183
245/40R18 $171
245/45R18 $166
255/35R18 $183
255/40R18 $181
255/45R18 $175
265/35R18 $188
265/40R18 $190
275/35R18 $198
285/30R18 $259
285/35R18 $228
19's
225/40R19 $194
225/45R19 $159
235/35R19 $181
245/35R19 $192
245/40R19 $202
245/45R19 $173
255/35R19 $197
255/40R19 $233
265/35R19 $214
275/35R19 $227
275/40R19 $251
285/30R19 $234
285/35R19 $229
295/30R19 $244
305/30R19 $260
20's
245/40R20 $232
255/35R20 $219
275/35R20 $243
285/30R20 $246
here's link to the rebate info:
Remember, you are helping to support Acurazine when you order from The Tire Rack and TireRack.com when you use one of the links posted or call me directly at 877-522-8473 ext. 4789 to place your order
Originally Posted by Bridgestone
The Potenza S-04 Pole Position is Bridgestone's Max Performance Summer tire developed for the drivers of ultra-high performance sports cars, coupes and sedans who want to feel the rush of driving their vehicle. Potenza S-04 Pole Position tires are designed to perform in warm, wet and dry conditions. However like all summer tires, they are not intended to be driven in near freezing temperatures, through snow or on ice.
The Potenza S-04 Pole Position features an asymmetric tread design with a large outboard shoulder, interlocking tread blocks and a central circumferential rib to enhance dry road steering response, high speed stability and cornering precision. High angle tread blocks in the intermediate ribs promote longitudinal stiffness to enhance straight-line braking forces while slanted lateral grooves pump water into wide circumferential grooves to help resist hydroplaning. Another continuous circumferential rib adjacent to the inside shoulder blocks enhances wear quality to help reduce noise throughout the life of the tire, especially on cars with alignment settings that specify negative camber.
The tire's internal structure features a lightweight belt package consisting of twin steel belts supported by a spirally wrapped aramid/nylon cord reinforcement that enhances ride quality and high speed durability. Active rubber inserts in the sidewalls near the bead areas tune vertical sidewall stiffness to blend cornering grip with ride comfort.
Originally Posted by Tire Rack testing
The Bridgestone Potenza S-04 Pole Position provides a great blend of handling and ride quality.
the lone 16" size
205/55R16 $105
17's
205/45R17 $110
205/50R17 $122
215/45R17 $114
225/45R17 $121
235/45R17 $131
235/50R17 $131
245/40R17 $146
245/45R17 $136
255/40R17 $159
18's
215/45R18 $134
225/40R18 $152
225/45R18 $154
225/50R18 $119
235/40R18 $156
245/35R18 $183
245/40R18 $171
245/45R18 $166
255/35R18 $183
255/40R18 $181
255/45R18 $175
265/35R18 $188
265/40R18 $190
275/35R18 $198
285/30R18 $259
285/35R18 $228
19's
225/40R19 $194
225/45R19 $159
235/35R19 $181
245/35R19 $192
245/40R19 $202
245/45R19 $173
255/35R19 $197
255/40R19 $233
265/35R19 $214
275/35R19 $227
275/40R19 $251
285/30R19 $234
285/35R19 $229
295/30R19 $244
305/30R19 $260
20's
245/40R20 $232
255/35R20 $219
275/35R20 $243
285/30R20 $246
Offer valid Sept. 1-30, 2013
justnspace (04-15-2014)
Just ordered a set, on sale, but no rebate. Now $154 for stock size.
