CCColtsicehockey's Home Projects Thread
Old 04-16-2024, 09:29 AM
  #1681
Received 5,845 Likes on 3,863 Posts
Looks awesome, nice updates! When are they starting interior finishes in the garage area?
CCColtsicehockey (04-16-2024)
Old 04-16-2024, 09:37 AM
  #1682
CCColtsicehockey's Avatar
Received 3,667 Likes on 2,498 Posts
I need to finish up my wiring still. Going to focus on the main garage areas for my work the rest of the week and this weekend as those are the ones that get drywall. I will have more time to work in the other areas after that. Basically still need to run conduit, speaker wire, and install blocking for the garage cabinets/media setup on the back wall. Then need to do all the blocking for the pressure washer setup and cabinets for the wash station. Few other odds and ends as well. There is still likely 2-3 days of work by the electricians as well. Probably half a day of work for the plumber then. Once that is done they can get final framing, electrical rough in, and plumbing rough in inpections done. Then they can move forward.
I have my numbers for the garage door size increase and I have to say I am leaning towards doing it just to be safe. That said the final piece is the builder wants to have an engineer come out and signoff that doing so won't weaken the rest of the strucutre while they shift that beam around. He is worried potentialy about the back wall pulling on the front wall while they raise the beam if it isn't supported just right.
I would say if I do all that then we are looking at at least 2-3 more weeks till they can start insulation then drywall.
Old 04-16-2024, 09:52 AM
  #1683
Nice! It'll be done before you know it.
Old 04-16-2024, 10:12 AM
  #1684
That is what everyone says but I have to say it doesn't feel that way while it is going on.
97BlackAckCL (04-17-2024)
Old 04-22-2024, 01:47 PM
  #1685
Not a lot happened in the last week except I picked the tile and ordered the cabinets for the loft since those will take some time to have made. The builder was happy I finally made the decision on the cabinets. Me being slow to decide on my tile made that a much harder than needed item. I had pretty much decided on a tile over 2 months ago but dragged my feet on giving the info to the builder to order. Ended up having to have it shipped from the Baton Rouge store instead of from one of the distribution centers which made shipping 2.5x more expensive. Lesson learned.
Got a little of the blocking I need to get installed done. Figured out the exact height of the pressure washer hose reel and then the shelving for a dual pressure washer system. Will be starting out with one but I wanted to have power and bracing figured out if I ever switched to two systems.
I also installed the bracing for the wall mount hinged network cabinet. The cabinet itself is roughly 49x24x24in. It also weighs 125lbs empty. It is will also hold a little over 200lbs worth of equipment once it is full as well. Being that it is also hinged and you are rotating that weight on the wall mounts I went extra crazy with this. Once the blocking was in place I put in 2x2 jack studs to support it. I am also considering putting a piece of plywood mounted to the blocking that is the same thickness as the drywall that will be used since it would be a more firm mounting surface than drywall.
Not garage related but home automation. The door sensor I installed on my backyard gate started acting up and randomly saying it was being opened and closed a couple of weeks ago. It got to the the point it would just do it nonstop for a while and then it stopped altogether. It seems the wire connector on the board for the external sensor went bad.
Ordered a new that is also an upgraded ZWave Plus model compared to the last one. I can't be too disappointed, based on my pictures from when I installed the original one, it is just over 7 years old.
The new one in the weatherproof box
Had to adjust the magnet because apparently the new one even though uses the same external sensor is much more sensitive.
The weatherproof box decided to show its age when I went to reassemble it. The plastic appears to have gotten brittle in the heat and 2 of the 4 nuts that are set in the plastic now spin freely so had to seal it with tape till I get another one.
godfather2 (04-24-2024)
Old 04-23-2024, 12:04 PM
  #1686
BreezyTL's Avatar
Did you make up your mind on the garage door height? I think last you shared you were waiting on info from and engineer to approve of it, unless I missed the update.
CCColtsicehockey (04-23-2024)
Old 04-23-2024, 03:38 PM
  #1687
Just got word today from the builder actually about the engineer. The information I received is exactly what I would expect from an engineer. The engineer said it can be done no problem. They will make no suggestions on how to go about doing it though. They will be happy to help figure out the repair though if it goes wrong. Gave my builder the what the fuck look with that info. I told him I would let him know Monday at the latest. I have to say I am learning towards raising the door height vs having regrets as long as I can get myself over the fact all 3 doors will not match height wise. I should likely modify my 3d rending for good measure.
Old 04-23-2024, 04:01 PM
  #1688
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,149 Likes on 4,816 Posts
I've never heard anyone say "I regret going with a larger garage door".
Old 04-23-2024, 04:18 PM
  #1689
Only 9in larger might be the crazier thing though.
Old 04-23-2024, 04:21 PM
  #1690
civicdrivr's Avatar
9" is way above average though.
CCColtsicehockey (04-24-2024)
Old 04-23-2024, 10:35 PM
  #1691
rockstar143's Avatar
Received 19,916 Likes on 14,458 Posts
Thankfully...
Old 04-25-2024, 08:55 AM
  #1692
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,418 Likes on 3,027 Posts
Old 04-25-2024, 05:10 PM
  #1693
I spent some time this week creating these new renderings. Decided to take the time to create the garage doors from scratch so they looked like what I would be ordering down to the inch. Also, found some more things in the SketchUp Warehouse I didn't think to look for to help make the rending look more like my house.
Here is the previous door height for comparison.
The following 3 users liked this post by CCColtsicehockey:
BreezyTL (04-25-2024), godfather2 (04-26-2024), SamDoe1 (04-26-2024)
Old 04-26-2024, 07:49 AM
  #1694
Received 5,303 Likes on 3,637 Posts
Bigger is better
CCColtsicehockey (04-26-2024)
Old 04-26-2024, 11:48 AM
  #1695
civicdrivr's Avatar
Remember that IG post I shared yesterday about the guy overthinking things...case in point
Old 04-26-2024, 03:37 PM
  #1696
Gryphon's Avatar
How big is the learning curve on SketchUp? I'm starting to get the itch to build out some models of the basement to try and determine what works and what doesn't for finishing.
I've been thinking about getting Chief Architect Home Designer as it seemed easier to produce a more refined interior look, which is what I'll need to help us make some decisions.
Old 04-29-2024, 06:54 AM
  #1697
I am a visual person I can't help it
civicdrivr (04-29-2024)
Old 04-29-2024, 06:58 AM
  #1698
I found it fairly easily. I took 4 classes of auto cad in high school so had that foundation long ago. Also, at one point considered myself a super user of photoshop but if you are familiar with any drawing type of app it helps the learning curve.
The biggest issue is trying to make sure you are always drawling on the intended axis you want to be. The basics though I think are super simple. You can find models of stuff to help you alone so you don't have to create everything from scratch. There are also tons of videos on youtube if you are stuck on something. For home design stuff I really like this guys videos https://www.youtube.com/@Thesketchupessentials.
Old 04-29-2024, 10:13 AM
  #1699
civicdrivr's Avatar
I'm just giving you shit. I still design a lot of things via excel
CCColtsicehockey (04-29-2024)
Old 04-29-2024, 12:23 PM
  #1700
Man SketchUp is free. You really need to upgrade.
Old 04-29-2024, 12:36 PM
  #1701
How the hell are you doing design work in Excel???
Old 04-29-2024, 12:41 PM
  #1702
cell by cell bordering on needing a cell in the psych ward
Old 04-29-2024, 12:55 PM
  #1703
civicdrivr's Avatar
that was a good one (and accurate too!)
Most of the things are more blueprint related. Like when I designed my shed. Each cell would represent 1/2", but some detail-heavy areas would even get down to 1/16".
I do want to learn SketchUp, but I could finalize my design via Excel and work on a cutlist for a large project in the time it would take me to learn SketchUp.
Old 04-29-2024, 01:00 PM
  #1704
JFC man, you need to watch some basic sketchup videos lol. It will be like discovering fire for the first time.
Old 04-29-2024, 01:58 PM
  #1705
This is what I was thinking.
Maybe an hour tops to learn the basics and be very fluid for multiple projects. Save a ton of time in the long run.
Old 04-30-2024, 08:14 AM
  #1706
BreezyTL's Avatar
Just get 3d software and be done with it. Try Inventor Fusion, its free.
Old Yesterday, 09:14 AM
  #1707
@CCColtsicehockey I was giving you shit about woodpeckers tools earlier but this one just popped up on sale and would HIGHLY recommend it.
https://www.woodpeck.com/delve-square-ss-20.html
Most of their stuff is cool but pointless/insanely overpriced but I bought this square a while ago and it's easily one of the most used tools in my shop and is definitely worth the money.
Marcelechka
Home & Garden
188
09-11-2022 11:53 AM
dallison
Home & Garden
26
09-21-2016 02:27 PM
drdamian
Home & Garden
29
06-17-2010 06:57 PM
KaMLuNg
Home & Garden
59
11-18-2008 07:50 PM
mantis23
Home & Garden
25
08-30-2007 01:00 PM
Quick Reply: CCColtsicehockey's Home Projects Thread
