How to install Hella DRL LED
Crazy Russian
Installation of these DRL is required in connection with the introduction of new laws in Russia, set up automatic DRL binding on all machines. I chose Hella DRL. Maybe the installation location is not the easiest thing, but after installing the DRL look like a native.
When I start the ignition, DRL lights at full power. When the headlights on, DRL lights at half power.
ichi d (07-17-2012)
That's awesome, I love it. How much did you pay for the LEDs, and what did you have to do to stop the normal DRLs (high beam) from coming on?
Thanks for posting the pics.
Edit: looks like you can find them for around $240 for the kit
I have a feeling that his car did not come with the high beam DRLs as he was required to have to install DRLs and chose the LED route.
Thanks for advise! I think I tryed all of the fuse and relays at under-hood fuse box. But all of them active all the time.
My be it will be better to continue on another thread? Because my problem should not hamper the owner of this topics.
https://acurazine.com/forums/showthr...6#post13909456
I see that your Hella LED dims when your headlamp is on. Hence when you headlamp is off it is brighter right?
My does the same as well. I installed a Hella Style on my RL before. Since my RL lease was up. I got a TL and installed a set of Nolden Slimline LED. My too dims when the headlamp is on and brighter when it is off. But I have a module where I can disconnect the wire when I can have it full bright if I have my headlamp on or off
My RL
Current TL
My RL
Current TL
Crazy Russian
About price: actually, you are right, on Russia it cost 240-250$
Crazy Russian
Crazy Russian
Crazy Russian
Crazy Russian
I used auxiliary box to take signal from the ignition.
It is start on after ignition "on" but the signal stays "on" about 2 min after ignition "off".
Turk will appreciate this.
Türk (01-17-2014)
Türk (01-17-2014)
MyKL (01-17-2014)
I'm here...
Thank you MyKL.
That's exactly what I'm going to do.
But I will use OSRAM
Osrams are directly connected to battery and they start when they feel alternator is running.
What about Hella?
Thank you MyKL.
What about Hella?
sockr1
10-01-2015 01:31 AM
Greengecko
09-16-2015 08:19 PM
